Junglepilot
When I installed the gearbox top plate over the longeron I used cherrymax rivets.
Now I am finishing up the top skin install and the segment of the dimpled topskin that lays over [the side of] that longeron area on each side is a well known tough rivet area. Many use the CR3214-4 (1/8" shaft with smaller 3/32 flat head for dimple).
I seems the edge distance rule shows it should be safe to use the larger 1/8" rivets in both areas. But could that significantly weaken that area with cherrymax 1/8" rivets in that small longeron section on BOTH the top and side?
Interested in opinions specifically from any designated examiners.
Sandy
![2009.12.15_-_RV-8_-_Gear_Tower_Skin_Attach_With_CherryMax_CR3214-4-4_Pop_Rivets__2__774.jpg](/proxy.php?image=http%3A%2F%2Fforums.matronics.com%2Ffiles%2F2009.12.15_-_RV-8_-_Gear_Tower_Skin_Attach_With_CherryMax_CR3214-4-4_Pop_Rivets__2__774.jpg&hash=6f434e27efaf98f2bb572907bacbbdc7)
Sandy
