Longeron Fit?
bullojm1
Today I fit the longerons to the aft fuselage on my -7. The instructions tell you to align top of the longerons with the top of the side skins - easy enough. However, where the longeron passes over the F-711 bulkhead, the bulkhead interferes and makes the best alignment I can get about 1/32". To illustrate my point better, here are two pictures:
Pic showing the gap:
Pic showing the interference:
Anyone else run into this on their project? The the verdict on the right thing to do?
I appreciate any advice.
Personally, I would file down the bulkhead slot a little for a good alignment. I had to on mine, not for alignment, but for fit. The longeron was real tight inthe notch. YMMV.
Nevermind....
Well that was easy to fix. Turns out my longeron had an every so slight twist, causing it to want to bow up. Once I clamped it down, everything snugged up nicely. Thanks for the reply.
