W&B help
I'm building an RV9 with a IO320 and an 18 lbs composite prop. In order to keep the CG in the empty weight design range, I ordered a 2" longer engine mount. I put together some calculations based on the data provided in the RV9 plans to determine a target CG.
I guest-a-mated the datum locations for the engine and prop based on the drawings and a note from Ken Scott that the prop on the demo RV9 was located 54 " forward of the wing leading edge. I can't confirm the actual locations because my RV is not that far along yet.
If anyone has the time I'd really appreciate another set of eyes looking over my work for errors. I sent a note to Vans, but find they're quite busy and don't have time to look the info over.
Here's the email with the info I sent to Vans:
Ken Scott to Me
10:30 AM (19 minutes ago)
Ok? look for a shipping call tag in your email soon. I?m afraid our engineers are pretty tied up and aren?t able to do individual consulting, so we?ll have to trust your numbers.
[email protected]]
Sent: Tuesday, February 16, 2016 8:12 PM
To: Ken Scott
Subject: Engine Mount
Hi Ken,
I have the Sensenich composite prop I bought through Vans, not the metal prop. I think based on the weight difference I'll stay with the longer mount.
These are my numbers, they are based on my engine weight at 291 lbs, moving it forward from location 28" to 26", using the numbers shown for the demo RV9 in the plans document (pg 14.4)
Removing the Sensenich Metal Prop off the demo RV9 at datum location 16" at 31 lbs and adding my Ground Adj FP (I bought from Vans) at location 14" at 18 lbs.
Below at my calculations based on the numbers in the plans (pg 14.4);
Weight Location Moment
Aircraft 1057 77,68 82107
Engine -291 28 -8120
Engine +291 26 +7540
Prop -31 16 -496
Prop +18 14 +252
Totals 1044 77.8 (cg) 81281
These calculations didn't include additional cowling length or the added weigh of metal in the engine mount.
Would it be possible for one of the engineers to look these over and see if I have made any bad assumptions or calculations?
If it checks out OK then perhaps you can email me a shipping label I'll round up a box and wooden base for to return it for honing
Thanks for checking into this for me and the help you've provided.
