Does not compute
prkaye said:
Question about altitude. If I wanted to operate my -9A on XC trips at altitudes between 10,000ft and 18,000ft (ceiling of the -9A?), would I need a turbocharged engine? Or would a non-turbo carbureted O-320 do the trick?
Trick question, what are the winds and atmospheric conditions (temp/pressure). What's your gross weight? How far is the trip? What kind of prop? (carb has nothing to do with it)
From my O320 RV-4 experience, at max gross/aft CG, fuel fuel, passenger, bags, 9-10,500 ft was all I could get and where it still felt good. Trying to get to 12.5 or higher was just not pleasant. Solo and light, sure 12,500 ft in the RV-4 and higher was fine. Decked out w/ O2 I few some trips as an experiment in the + 16,000 ft range. My fuel burn down and spacific miles per gal up, but I was going slow. It took a lot longer to get there, but than I skipped a few gas pumps. The RV-4 is not slouch. A 160 HP RV-4 has 1,000 ft higher service ceiling than a 160 HP RV-9A. Of course the RV-9A's gross is higher by 200 lbs than the RV-4. That just shows you how important weight is. KEEP IT LIGHT.
I suspect a O320 RV9A is similar but may be able to pull off a few more thousand feet with the longer wing and still have a sold feel, so the first thing I would say is experiment!!
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You need to fly it near service ceiling light and heavy. Take data and find out what the plane likes. I have no RV9A time, but I can speak to the basic principles of altitude flight and turbo charges.
So lets assume a 160 hp RV9A, Sensenich prop with proper pitch, standard day and zero wings. My common advice for VFR normally aspirated engine GA planes is 8,500-12,500 ft for practical and efficiency reasons. Why do you want to fly at 18,000 ft? There is no real reason. Trying to TOP convective weather in a single engine plane is not a good idea.
Do you need a turbo? NO. Turbo charging was covered in a recent thread; the bottom line it's: heavy, expensive, does not fit under a RV cowl easily. Also Vne speed goes down with altitude. It would be easy to exceed Vne with a turbo at altitudes above 10,000-13,000 ft, so the benifit on the RV airframe is limited, unless you increased Vne and added more fuel. Turbo charging maintains power at altitude. Yes you go faster but you burn more fuel, no free lunch. I talked to a turbo RV pilot, it flew high and fast, but not that fast and drank lots of fuel. You have to pay to go fast. You want to go fast in a RV, stay on the deck and leave it wide open. You will get there in a hurry, just try not to cry like a little girl at the gas pump.
Looking at Vans ** service ceiling numbers for the RV-9A for 160 HP:
Solo:....24,500 ft
Gross:..18,500 ft
The answer is, it it practical? Of course
you can physically fly up to 18,000 ft without a turbo in a RV9(A), but read the definition of ** service ceiling below.
The practical part is sucking O2 thru a mask, staying warm and going real slow, I mean slow. Nothing wrong with going slow; you will get great miles per gallon if the wind is favorable. Depending on time to climb and trip length; Even solo, I would say 18,000 feet is not real practical or efficient, but 13,500-15,500 ft may be practical at lower weights and standard or better day's (cool). Flying high means going slow, but you will be nearing you best miles per gallon.
Most people don't have the patients to fly that slow, but with a good tail wind, its like free lunch. The problem is knowing the real winds aloft. Often you don't know until you are there. Learn the ATC freqs and see if they can ask any higher flyers what the winds are. Almost all planes have ADC's (airdata computers) and can give you winds. So plan on a lower altitude and then step up as you burn fuel or if you think there is more winds to be had. Bottom line 8,500-9,500 ft is your everyday get there, 75% X-C altitude. You want to fly near 55% climb up to 11,500-12,500 ft. You don't need O2, good econ and decent true airspeed. Now if you are one of those fire breathing 180 hp and 200 hp RV lone eagle jockey's, than fly even higher, but break the O2 bottle out. I don't care for O2 myself, unless I have to; some times its nice to have the option to climb up into strong tailwinds. Higher HP gives you more altitude capability even if its not a turbo. So the RV-7/8 with a large engine can make up for the shorter wing with raw power. That's why I went with the 180HP RV7 and the acro/fuel range.
In general for any GA plane RV (non-turbo), HP drops, lift drops, speed drops but MPG's increase to a point. As you get near your ** "service ceiling" you are start to get below best range or long range cruise speed and nearing the bucket, backside of the power curve. Before that the plane's feel is not pleasant, mushy. Some Jets do the same thing when you get high: lift is down, thrust is down and they start to mush along. The old B737 was not real happy heavy and high up, but the newer "long wing" or "new gen" B737-700's flys nice high up w/ a higher aspect ratio wing. However keep in mind HP on piston engines drops off way more than a Jet engine does. Jets have tons of sea level reserve power for single engine performance and altitude performance; also jet engines benefited and increase in efficiency from colder temps and higher speeds. Pistons don't work that way, temps and aircraft forward speed has minor or nil affect on engine efficiency.
Yes you could turbo the RV-9A and fly at 18,000 ft but structurally the wing and controls are not designed for high speed flight at extream altitudes, i.e., Vne. Where a jet wing is made to fly high. YES THAT'S IT a sweep-ed wing RV9A with a jet engine.
Also what speed do you want to fly? Our RV's will fly 100-110 mph, but we also want to get there today! You can just fly at 500 ft and throttle back and get good gas milage and a great view. There's is max range, max endurance, long range cruise, min trip time and so on.... At some altitude, speed and power setting for the weight and condtions there is an optimal balance of speed, economy and practicality. You are the PIC, so you decide. In general for normally aspirated engine planes like the RV its under 12,500 ft, giving good speed, econ and got to get there today time.
Hot and heavy best alt may be as low as 8,500 ft. If there are head winds, 1,000 ft may be best.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Its a question that can't be answered completely but you do NOT need a turbo.
** Service Ceiling: This by definition means hanging on the prop, with a handful of MPH above stall and max climb rate of 100 fpm by definition (and no down drafts). I arbitrarily subtract 6,000 ft off these numbers for max semi-practical cruise for 18,500 ft or 13,500 ft for solo/gross. Of course you will need O2 to breath. At night you should be on O2 before 12,500 ft.
