So, following the plans, I've reached the stage in my RV-7 tailwheel slow build of building the seat backs.
The plans have you make the F-637B & C parts from stock AA6-125x3/4x3/4 and AA6-063x3/4x3/4.
The only stock of those angles I have left is some very long angles that came with the wing kit and wrapped in a note saying DO NOT CUT! I have two 7'/8' lengths of each size.
The longerons are all done and riveted so I know it can't be the longeron angles.
Is it time to use these long angles? If it is, do I use one length up first then the other or try and use up each one evenly so I have the same amount of angle stock left on each length?
Even though I've read ahead, I'm worried I've missed something critical and that I'll need a long length of angle down the line.
Abe
Abe
