Good Morning to all.
This has been a 10 year project and we are closer than ever. I'm in the process of putting the lower skins on and would like some input on the location of certain components so wiring can be competed.
Most components are really simple. IE. nav/strobes, landing lights, outboard occillating vans lights, heated pitot. There locations are all set.
The questions:
1.The Garmin aileron servo. Should it be located in the left or right wing.Does it matter?
2. The Garmin remote compass. Left or right wing or in the tail? My concern with the tail is that the trim cables are magnetic and may be cause for concern.
3. Is balancing the weight between wing a concern?
Thanks in advance for your valued input!
The questions:
