Bob Brown
On my RV-7, I'm still living with a poor choice made early on in the build process by putting my "forest of grounds" single point ground in a poor location sort of directly above the battery. It interferes with changing out my battery...not that it can't be done, but I have to remove several wires from the ground tabs, use a duct tape hoist method and hold my tongue and roll my right eyeball just right to get the battery in and out. So where are people putting that single point ground from B &C on the firewall of the RV-10?? Are you happy with where you put it? If you're not, why? Where would you put it "next time?" I've looked at lots of RV-10 build sites, but haven't seen much detail in this area. I plan on three stainless wiring penetrations from Plane Innovations, two 1" and 1 3/4" to handle all the sensors and electrical stuff. So come on guys, come forth with all the pics of your single point ground installations...please!
