location of fuel vent fitting through F902 bulkhead and gear web
alpinelakespilot2000
Question on which hole in the gear web attach (F9101) should be enlarged for the fuel vent fitting that goes through the F902 bulkhead and gear web attach. Four holes connect the F902 to the F9101. Is it the third hole from the bottom or the top (fourth) hole?
Argument in favor of third hole:
Dwg 23, View G-G clearly seems to be indicating the third hole
Argument(s) in favor of fourth (top) hole:
a. Dwg 36, View D-D and location C-10 and D-7 seem to clearly indicate the top hole
b. the top hole is most closely aligned with the 3/4" hole that exits the fuselage through the gear web to the tanks (and would allow the vent line to run parallel to the floor).
Thanks.
