Location for air oil separator return line on engine
jgbmo
Active Member
I have an IO-360-A1A in my RV-7, and I'm getting a fair amount of oil on the belly of my airplane. This is especially true if I have more than six quarts of oil in the sump. I'm wanting to install an air oil separator, but am not sure where to connect a return oil line. I've seen where you can weld a bung onto a rocker cover, and connect there, or drill a hole in the dipstick tube and add a self-sealing clamp. Before I do either of those (or pull off the baffling to add a T to one of the cylinder oil return lines), I was wondering if there are any removable plugs on the accessory case of crankcase where I could install a pipe fitting. Suggestions are appreciated!
What Mahlon posted. 3/8-18 NPT.
Oil return line
Hi John, I just finished installing mine in the accessory case as mentioned above.
My plug was an internal wrenching plug that I promptly stripped while trying to remove it.
Ensure you clean out any paint and make sure the Allen wrench is well seated when you try to remove it.
I was very lucky and was able to remove mine with vice grips.
Terry
The half raven kit comes with a standpipe return fitting that goes into an unused drain in the oil pan.
I was worried about striping the plug.
The prop governor access cover is easy to put in a NPI thread with a tap.
(I have fixed pitch prop)
I think the guy from Anti splat suggested it. Worked well for me.
