Recently someone gave me a DMC kit that has a lot of the bells and whistles needed to make up wiring harnesses. Some I already have and some I don’t, so I have a few of everything that you would need to make up both Garmin and SkyView connectors.
What I am wondering if there is a need for a kit that can be loaned out, and moved about the system when someone is ready to wire up their panel.
It will include a DMC AFM8 crimper, the positioners needed for both the normal pins and Garmin HD pins. Wire strippers, and wire cutters, and a DMC crimper to put on BNC connectors for RG400, and anything else you think might need to go in the kit, all in a protective box.
You will need to supply your own pins, pin insertion and extraction tools.
I will have a few restrictions, like a nice deposit to protect my investment, which will be returned fully when the kit is returned complete, and with no damage to anything in the box in a reasonable time so others might use it. Another one is shipping both ways is on the borrower.
Anyone who know how good the DMC stuff is, you will understand the deposit, but you will get it all back if it is returned just like you received it. This is better than going out and buying it all yourself just to use it for a week or two.
There is a few other things that would have to be worked out before I make the kit up, and start loaning it out.
Let me know if this is something that might be needed.
Brian
Brian
