Some general issues to think about
My disclosure: I didn't end up going with Light Speed + P-Mag, but I did consider it. (I ended up going with two P-Mags.)
Some general issues for you to think about:
If going with two electronic ignitions of any kind (two Light Speeds, two P-Mags, one of each, whatever), you are now in the realm of an electrically-dependent engine (yes, even P-Mags depend on ship's power at low RPM's, as well as for backup if the internal generator fails). Now, there's nothing wrong with going electrically dependent IF your electrical system architecture ensures that no single failure scenario can take out both ignition systems. The overall system design must ensure that a simultaneous failure of both ignitions is more-or-less astronomically improbable (or at least less probable than two mags failing simultaneously! that probability is less than astronomical...). This can actually be ensured in a variety of ways, the best of which is probably to run two complete electrical systems that are independent of each other (becoming more and more common these days anyway, as aux electrical systems replace vacuum systems for cockpit instrument power redundancy). Still, many folks shy away from that, and that's why you see many instances of one electronic ignition and one traditional mag in RV's. Not unreasonable, there are trade-offs both ways. I won't get into the relative merits of electronic ignition vs mags here. Plenty of info on the topic is already available.
But anyway, so the first thing you need to decide is whether or not you're comfortable with the prospect of running two electronic ignitions, and are willing and able to design your electrical system architecture accordingly.
If the answer is no, then stick with traditional mags, or one traditional mag and one electronic ignition.
If the answer is yes, then continue reading.
So you've decided to go with two electronic ignition systems. Now the question is what type, or what types if two different types.
One advantage in favor of using two different types is simply the fact that they're different from each other. Dissimilar redundancy. This makes it less likely that the two systems will have the same failure modes, and therefore less likely that they will both fail simultaneously under some particular set of conditions or as a result of some yet unknown design flaw.
One disadvantage of using two different designs is that they'll have different installation requirements, different operating procedures, different companies you'll be dealing with for support, etc. Just more different things for you to juggle, as a builder, maintainer, and pilot. Although maybe not drastically so, since all ignition systems are pretty straight forward, but still.
Now for me personally, all things being equal, I probably would have gone with one of each for dissimilar redundancy. But all things are rarely equal. After studying both products, I chose to go with two P-Mags because I was satisfied in my assessment of that product, and I was just not satisfied with certain aspects of the Light Speed product. Now, I don't want to get drawn into a discussion here about brand A vs. brand B, though I'm sure others will chime in with a full spectrum of opinions on both sides... But I will just make the point that any product or products you choose to install in your airplane, especially a safety-critical component like an ignition system, should be selected with due diligence and scrutiny to your own satisfaction.
