light kit wiring
music1
Member
I have the lighting kit and not finished closing in the left wing and have one white and one string inside the wing. I looked at the instructions on what to do with the electrical part of it and really don't understand it dahhhhh??:confused: can anyone explain it better to a confused guy please
I thank you in advance
Put in an extra wire (now!) to each tip light. This will enable you to switch the strobe part and the light part separately with the new avionics panel. For specific questions it helps if you post plans page and step. You might want to wait on building the tab-connectors at the wing roots because the new avionics system has an improved plug rather than those tabs. See the pdf file linked in this thread: http://www.vansairforce.com/community/showthread.php?t=74469
