careful - it matters
I leveled my fuselage using the inner forward skin, as described in the plans.
I found that this is NOT the same as leveling the cockpit longerons - it is a slightly different angle.
When you set up the gear so that the front edges of the two struts form a straight line (I used plumb bobs with no trouble), it defines the fore-and-aft position that the outer gear saddle rests. I found mine ended up well centered in the gear opening in the skin.
Other posts on this subject have shown pictures where the outer saddle is offset well aft of the gear opening, requiring some skin trimming - I suspect this is because of improper fore-and-aft leveling. I think if you level the cockpit longerons instead, the front edges of the two gear struts will line up straight with the gear set slightly farther aft.
On the other hand, I ended up with about one degree of toe-in on both gear, which required a shim on each side. So maybe I shouldn't have set them that far forward?
For sure in any case, be sure they are both the same distance from the tail wheel. Also be sure to observe the 3/16" dimension for the outer saddle from the edge of the longeron. If you exceed a 1/4", you will make the saddle bridge across a slope discontinuity between the longeron and the inner structure.
