Thanks to everyone who responded.
Yes, I realize every plane will be a little different & just wanted the approximate dimension. For fine work, I have 2 bottle jacks which will be stable after I get my bracing welded together.
Since Dan says 4", that sounds like 2x4 (3.5") frame with 1/2" plywood sheathing. Then adjust as necessary using tire pressures.
