AAflyer
I'm wiring my RV-8, & I will not be using the old-style headset jacks, and am a little confused as to how to substitute the Bose LEMO jacks that I recently acquired. My Skyview harness has 4, shielded 3-conductor wires that I need to wire to my 6-pin LEMO jack. The LEMO harness has 2, shielded, 2-conductor wires along with 2 pigtails that come from each of the shields, AND a red power AND a black ground.
My biggest confusion stems from all the grounds?and how to incorporate 2 PTT switches in my grips.
As far as the shields and grounds?do I need to splice the shields of the Dynon harness and the Bose harness so that it essentially creates a continuous shield from the jack all the way back to the interphone box? And should this ground be kept separate from the power ground??and the PTT grounding? Should all these grounds be plugged into the same grounding terminal?
Any chance someone can supply a wiring diagram that even a caveman can understand?
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
