There have been past postings on this but I am unable to resurrect them. I'm coming up on buying a pair of headsets - probably the Lightspeed Zulu 2 - it comes with an assortment of terminal fittings. I'd like to go with the LEMO plug as it is the cleanest and simplest hookup, one connector instead of two, and eliminates the battery box hassle with an ANR headset.
As noted in the previous (un-located) posting, Vans promised this powered headset feature in their Skyview PDF - page 31. This feature seems unsupported in the Wiring Diagram for Finish kits shipped prior to 8/25/2011 (mine) and for kits shipped after that date, the Power, which seems to sit on Pin 1 of ES-00042, is not utilized.
Installing the LEMO config after Cert is possible, but then you have the wrong headsets. Adapters are available, but they introduce more bulk and are costly.
Has anyone installed the LEMO headset power lashup? Prior to certification? What is the effect on the requirement to "Build per Print"?
Bob Bogash
N737G
Bob Bogash
N737G
