OK, so now I have to rivet the counter balance assembly, which is all riveted together, to the spar. It seems like it would have been easier to rivet the E-903/904 subassembly to the spar and then rivet the counter balance skin on. But the instructions say rivet the whole assemply together and then, after riveting the top skin to the spar, rivet the whole counter balance subassembly to the spar. I need helpful hints. There is little clearance between the leading edge of the elevator and the rib flange to get either a bucking bar or rivet gun on the rivets. How did you do it?
