Guys,
The two rivets that attach the outer rib to spar on the elevator.....I was not satisfied with one of the rivets and chose to replace it. In the process of drilling it out (tight area) if kinda elongated the hole. It is spec'd for a 470D4-4 rivet. I would like to drill it out and install a larger rivet. Van's support did not see this as an issue, but what do you guys say. In short I want to replace a 4-4 rivet with the next size up...I would guess a 470D5-4 or 5.
