I just want to be sure that I'm not about to screw something up here. I'm about to trim the elevator counter balance weights as one of the last steps. Per the plans there are notes about not trimming the left inboard aft edge, but this note is on the right elevator plan.
When you read all the notes *I* think this is what I'm supposed to end up with, I'd just like some confirmation.
Both elevators - Trim top and bottom per detail on Dwg 5 (right elevator) plans.
Right elevator - Trim BOTH aft edges of weights per detail on plans.
Left elevator - Trim ONLY the aft edge of the outboard (tip side) weight, leave the inboard one alone.
This seems to be what the drawings indicate, but when read several times I could see how one could easily be confused.
TIA
TIA
