Hi all, well I've finally come to the point where I need to pressure test my tanks before final assembly onto the wing. The first, no issues. the second, not so much. I have a tiny leak, it seems I took the precautions in the manual a little too literally and when I riveted on the rear baffle. I went a little too light between 2 rivets on the bottom of the tank. You know where they say to not use too much pro seal so that the water can drain to the low point... So what do you think I should do? The rivets in question are on the bottom of the tank, rear baffle, outboard last 2 rivets in the same bay as the filler cap. Part of me wants to drill out the last couple of rivets on the bottom outboard flange of the rear baffle, inject in some pro seal and close again using oops rivets? Maybe figure out a way to get at the problem area through the filler cap? Or the last resort is cut open a small hole in the rear baffle and re apply pro seal and seal up the access hole.
What does everyone think?
thanks in advance.
Trevor
thanks in advance.
Trevor
