Terrance Medemblik
Member
I was wondering if any -7 builders have used Locktite 290 to seal a leaking rivet in a fuel tank. We have tried an application 3 times now by applying a negative air pressure in the tank (slight vacuum); the loctite 290 appears to draw in, but fails to seal the leak.
When we apply a small amount of '290 to a piece of aluminum, it does not appear to "set up", even after 3 hours. Can anyone comment on this and if you have been in a similar situation, do you know of alternative methods of sealing the leak?
i am not looking forward to cutting a hole in the aft baffle and re-sealing, although this appears to be a last resort. Thanks in advance. T
