s10sakota
Hi, for those of you that used pop rivets to rivet the aft flanges of the leading edge ribs to the spar, is there a trick you used to reach all of the ribs?
I can rivet the 2nd, 5th, and 6th ribs. I can't rivet the others because the rivet puller tool doesn't fit between the ribs. I'm thinking of maybe cutting a few inches off the handles? Or maybe I can grind away enough of the head to fit it in at an angle? Any tips here?
Also, for those that used solid rivets, I have the offset back rivet set, but what would I use against the manufactured head?
Thanks!
Thanks!
