CharlieWaffles
I cleco'd my leading edge to my left wing this afternoon. It all looked good and I squeezed the bottom rivets, riveted the ribs and then saw that the rivets for the rear nutplates in the seam are touching part of the main spar. On the bottom side, it appears the offset of the rivet is about the thickness of the difference between the spar and the stiffener. On the top, the ricket is a bit thicker. Not sure if this is by design? Perhaps its just a case of the top rivets needing to be set more?
