RV7AJeremy
I know that I can substitute LP pull rivets for the solid rivets for the internal rib to spar attachment on the leading edge assembly. What about the two end ribs, has anyone used LP rivets for all the rib to spar attachemnts? I will call vans in the morning but I just wanted to know if anyone else has used pull rivets for all the rib to spar rivets. I hope this makes sense, it is difficult to put into words. I attempted solid rivets with much frusteration.
Thanks in advance...
