Craw
Active Member
Gooday All,
I am doing my best to put together a wiring diagram for the LC-50 Lighting controller:
(https://static1.squarespace.com/static/5282b286e4b01dd0edf58599/t/5343f341e4b0f92a7a690686/1396962113578/LC_50_Manual.pdf
wired to dim various Garmin LRUs as well as two of these LED strips (dual white/red):
https://www.aircraftspruce.ca/catalog/inpages/flexibleLED_red12.php
The idea being to have a total of 2 dimmer knobs: 1 dimmer to control the Garmin LRUs and a second dimmer for the two LED strips (1x in the Glareshield and the other in the footwell of an RV-7A).
Lastly, I would also like the LED strips to be controlled by a three position (on-off-on) DPDT switch, one position for red LED lights, Off position and one position for white LED lights.
I have uploaded the draft diagram I have been working on but got stuck at the DPDT switch and LED strips. Could one of you help me complete the drawing and confirm the elements already shown are correctly wired.
Draft wire diagram: https://ibb.co/y5dk9wy
Thanks in advance for your support.
