I'm findind both front latch pins to be a little short in the standard Van's configuration. The tapered end goes all the way thru the alum door post but not far enough for the full tubing part. It only makes it thru the composite part of the door post. I'm thinking of making two new ones about 1/4" longer. With the latch in the open position the pins are still about 1/4" from protruding out of the door, leaving roam to lengthen about 1/4".
Anyone know which type of alum alloy these pins are made of ?
Thanks Ron
Thanks Ron
