Just ran engine for first time. XP360 with Lasar.
At 1700 rpm did a mag check. All parameters were good . when I went back to both mags however the rpm climbed about 200 rpm to 1900rpm without touching the throttle. The lasar light also went on. The light stays on for 20 seconds as per the manual , but why do the revs climb??
Is this normal???
Is this normal???
