Can you show the FAR that states strobes must be used during daytime please?
Reason, I’ve never heard that before and darn near everyone at our airport is non-compliant.
If so, I’ll bring it up at the next EAA meeting.
Thanks.
Far 91.209 (specifically paragraph b. Notice, paragraph a talks about night operations, paragraph b doesn’t limit itself to night, so it applies to both day and night.)
§ 91.209 Aircraft lights.
No person may:
(a) During the period from sunset to sunrise (or, in Alaska, during the period a prominent unlighted object cannot be seen from a distance of 3 statute miles or the sun is more than 6 degrees below the horizon)—
(1) Operate an aircraft unless it has lighted position lights;
(2) Park or move an aircraft in, or in dangerous proximity to, a night flight operations area of an airport unless the aircraft—
(i) Is clearly illuminated;
(ii) Has lighted position lights; or
(iii) is in an area that is marked by obstruction lights;
(3) Anchor an aircraft unless the aircraft—
(i) Has lighted anchor lights; or
(ii) Is in an area where anchor lights are not required on vessels; or
(b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off.
