Kyle do share,
I was thinking LED but HID for $150...
KC
Here's what I'm working with:
http://trailtech.net/single_hid_scmr16.html
I currently have one of the 36 degree dispersion units. I will also be installing one of the 12 degree dispersion lights.
The light with the 36 degree dispersion is an outstanding taxi light, but as a landing light, it is only slightly better than the 50W Duckworks landing light I used to have.The 12 degree light *should* be an excellent landing light with the ability to throw a beam a long way down the runway.
In the end, I will have one 36 degree and one 12 degree light side by side in my single Duckworks housing. This will be a tight fit, but will not require any modifications to the leading edge cut-out.
Here's what I can tell you about these lights:
- They are self contained. All you need to do is create a mounting solution, hook 'em up and they are ready to go.
- I have experienced none of the radio noise which is sometimes associated with HID ballasts. This may be because the lights are sealed in a metal housing.
- Despite the manufacturer's indications that these lights need airflow around them (or they may shut off), I have not noticed any heating issues despite having mine sealed inside the wing.
By the way, the link is to the manufacturer's website. A google search will turn up better prices on these lights. Also, there are some other interesting lights on the trailtech website, but I think the SCMR16 series fits my application best.
