If you’ve got the newer wings in which Van’s has already punched the lens cutout, they should be identical. After making the left lens, I’d simply trial fit the left lens on the right wing skin cutout to verify. If you’re cutting the openings like I had to do, I wouldn’t assume a perfect match.
