Wouldn't be too much different. The light is cut into the leading edge in the outboard bay. Once the wingtip is off there is pretty good access there. You'll have to run a power and ground to it. (Or just power, then ground locally, ymmv). Duckworks makes a good mounting bracket and template for cutting and both LED and HID options, LED seems to be the way to go anymore.
