the right landing gear weldment WD821 does not line up as well as it should. it sits higher than it should. some good effort has to be made to get most of the holes in the vicinity of alignment. the only remedy I see is cutting off the front part of the fus. and starting over, paying closer attention to the fit of the longerons (F843?) in that area. thoughts? if alignment requires effort now, it can only be worse come wing-attach time.
