Deleted
R RobB52 Active Member Aug 18, 2018 #2 Tom, I am having the same issue. Did you stack three shims on one axel? And did you need longer bolts?
RV-14E Well Known Member Aug 18, 2018 #3 On my build, I found I had toe-in on both sides: 0.32° on the right and 0.1° on the left. With a 0.25° shim on the right, I'm at 0.07° on the right and 0.1° on the left. I'm curious if you had to remove material from your gear leg to get it to fit? I wonder if that process can adversely affect toe.
