Not sure if they use sleeves
but gear leg weldments were the proper size to fit the gear leg at the top and the bottom, but NOT in the center section. They either turned the tube to larger inside diameter in the center to provide the relief, or they welded in insert tubes at the top and the bottom.
Seems to me if they didn't do something to make the socked ID larger in the center area, the gear leg would be a real bear to get inserted fully...
