Ottertrack
Member
I wonder if anyone else has had this problem. I am building an RV-7A and am fine tuning the Landing Gear Mount. The problem is that to have all contact points of the mount up tight and flush with the web of F-704A Bulkhead, I would have to grind about 5/16 inch of material away on the aft side of the landing gear mount hole in the Forward Bottom Skin, F-772. This would encroach into the rivet hole in the F-704A flange. Any ideas on this? Thanks a lot.
