flyingbeaver26
Active Member
Today I got around to test fitting the landing gear. I used 4 plumb bobs like the plans specify. After about 30 minutes of tweaking I felt like I got them perfectly lined up. On the left gear, the rear bolt hole in U-803 bracket is almost totally hidden under the skin and flange for the 6-32 screws to secure the cover plate. I'll need to trim away a bit of material to get access to drill the hole in this area and tighten the bolt. Before I start cutting, I want to see if anyone else out there has had this happen on their build. Is it normal to rim away a bit of material in this area? This fuse is a QB.
Brad
Austin TX.
Brad
Austin TX.
