Not sure if I qualify to give advice since I'm not flying an RV yet. But I do fly a kitfox(tailwheel) and that thing is very touchy and I've been told and I agree, it is tough to land. I fly quit a bit, usually every day. I do spot landings and others to keep from getting bored. Now I've done every thing on landings and have tried different things to help out the landing. I find that if you have too much prop, meaning a fixed prop on landing you will float almost forever. I guess my question now would be, what prop do you have?
Next if the idle is too high can cause floating, which is what I think you are having. If the prop is set too high, coarse, or fixed pitch than you have more fan blowing, if the idle is set too high, even with a cs prop you can float.
My solution is to lower the idle as far down as you can, doesn't mean you run on the ground at this setting, just means you have a tool in your bag that allows you to pop off the power to get er down, so to speak. With a flat prop and low idle you can really slow yourself down quick and than you raise the idle back up on that last entry to the numbers, than if I can't get the plane down on the runway, I take and pull off the power to get it to sink on the runway, just as it touches, I put the throttle where normal idle is. I have the Rotax engine and this really works sweet for me. I have my Rotax set at 600rpm, it's suppose to be set at 1800. I always run it at 1800, and never let it run rough. Odd thing, in the air when the aircraft is flying, I can pull all the way off and it's nice and smooth, but I sure slow down. way cool.
On wheel landings, if I make a perfect wheel touch down, but the idle is up or at normal, I find it very hard to lower the tail, it goes and goes with the tail up. If I pull the idle all the way off, than the tail comes down, as it makes contact, than I raise the idle back up.
Now, I don't know your configuration, but I would check your idle and make sure it is down, not running even a little to fast. If possible, lower the idle to the lowest before quiting. Not sure if you even want to have that option. But I love it. Not sure how low you can go with a lyc, I'm sure I'll find out in the future, because I love low rpm settings.
Now, when I did my transision training, I know in a 6A, but, I found the only way to land it was to fly it right to the runway, as soon as it touched on the mains, and the nose was already up off the runway, I pulled all power off, which wasn't very much and it stayed down.
Make sure your approach speeds are correct. On my fox, the stall is about 40, lower in ground effect, about 38. If I'm doing a wheel landing, I like 60mph just before the runway, maybe 200ft out. If I'm doing a 3point, I want 50mph at 200ft. out.
Have you flown with an instructor, preferably somebody with rv experience? Might concider doing that. That way someone can watch you and evaluate what is going on.
