Anyone have the pin out diagram for a KT-78 (same as Cessna 300) transponder. Thanks in advance!
b17fe Well Known Member Aug 21, 2008 #1 Anyone have the pin out diagram for a KT-78 (same as Cessna 300) transponder. Thanks in advance!
J JHines Well Known Member Aug 21, 2008 #2 Found on the "Internets", use at your own risk: http://www.aeroelectric.com/Installation_Data/KT76-78.pdf
b17fe Well Known Member Aug 21, 2008 #3 Any idea what the A,B,C (1,2,4) circuits are in that diagram? Encoder inputs or ? Thanks Johnathan ! Last edited: Aug 21, 2008
az_gila Well Known Member Aug 21, 2008 #4 Altitude b17fe said: Any idea what the A,B,C (1,2,4) circuits are in that diagram? Encoder inputs or ? Thanks Johnathan ! Click to expand... Altitude encoder inputs in parallel form.... as ahown in this corresponding connection to an ACK encoder. http://www.aeroelectric.com/Installation_Data/ACK_A30.pdf
b17fe Well Known Member Aug 21, 2008 #5 az_gila said: Altitude encoder inputs in parallel form.... as ahown in this corresponding connection to an ACK encoder. http://www.aeroelectric.com/Installation_Data/ACK_A30.pdf Click to expand... Makes total sense now ... thanks Gil !
