KLX-135a Sidetone
ExtraKatana
The sidetone when keying up has never worked in my 6A.
Bought it this way. Anyone have a clue as to what didn't get hooked up or what to adjust? I do have another intercom the Com runs through....it works fine for volume/squelch etc.
there is an adjusting screw ...........
on the back of the radio. might help. turbo
And these radios ship, by default, with their sidetone turned all the way down since most installations employ a separate intercom that provides its own sidetone.
Try this
If I remember correctly, when you slide the radio out of the tray, you will see a couple of holes on the top or bottom of the radio. (They may be covered by a circular piece of tape.) One of these should be marked Tone, Side or Side Tone.
Through that hole, you can access an adjustable pot to turn the sidetone up or down. You will need a small screwdriver to do this. Make a mark with a sharpie as to where you started and then adjust, using trial and error, to get the amount of sidetone you want.
Good luck.
