The trick is to put all of your favorites in the FPL25 page, that way when your on the FPL tab you just left turn the small knob once, hit CRSR, and pick what you want.
I like the King GPS's, they're easy to use once you know how. You can pull the GPS out and just connect power to a bench power supply, ground and the takehome pin to ground to play with it at home.
