Rv8Medic
Member
Hello all,
I'm looking for some advise as to how to wire a kill switch to deactivate the rear stick while the pilot in front is flying or visa versa. This needs to be done so there are no "counter inputs" to the flap or trim motors as well as keeping the kids from hitting the additional switches on the stick (flaps, fuel pump and A/P disconnect). I've heard some say just send all the grounds to a single switch but have also heard others say you need some sort of rotary switch. Any suggestions? I dual infinities with trim, flaps, PTT, A/P disc, Boost pump, and transponder ident. Thanks!
