claycookiemonster
My Master/Battery switch has a threaded body with a diameter of .750 inches.
However, the sides of the switch body are flattened, and those flattened sides are only 5/8" apart.
My initial plan is to drill a hole 5/8" in diameter and then file the flat sides into the hole. After the flat sides are right, I can file top and bottom to get the 3/4" diameter for the overall switch body.
I know that will work, but I'm wondering if there's a simpler and better way?
