tomhanaway
My two piece overhead console runs from baggage bulkhead all the way to the front (air conditioning flow). The rear 1/2 is permanently fiberglassed in.
I'd like to keep the front 1/2 removable for future access. The front 1/2 is already covered with headliner and has a 2" +/- lip on each side for mounting. Currently have overhead light and gps wiring running inside tunnel. I'd like to avoid an access panel as being able to remove the whole front half will look cleaner.
Is there a recommended way to attach? Velcro? Sheet metal screws?
My concern with the sheet metal screws is that they would start to loosen after several install/removals.
My ideal would be some sort of hard nut floxxed into the canopy top (not all the way through) but I'm not sure about drilling more holes in canopy.
I'm leaning towards some click bond posts which would be the least invasive.
Appreciate any thoughts or comments.
Tom Hanaway
Boynton Beach, FL
Tom Hanaway
Boynton Beach, FL
