What I've learned so far...
I have been working on the tanks for a couple of weeks. Here are some things I've learned. Of course, I am not finished, so it's up to you how much to believe from the guy who hasn't pressure tested his tanks yet...
1 - Get TWO quart kits of Proseal. Vans says one should be enough, but as another local builder told me "After building many many sets of tanks, Vans knows *exactly* where to put it -- you and I don't
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
". There is no way I could have done everything with a single quart kit.
2 ? Instead of popsicle sticks, I cut a piece of 1/8? thick lexan into well..popsicle stick-looking strips. It won?t break, but it is nice and flexible so it won?t scratch anything. It was also very easy to shape with my grinder. I also happened to have lexan laying around, but not popsicle sticks?
3 ? Get an inspection mirror. I got mine for something like $5 at aircraft spruce. VERY useful for inspecting rivet heads that don?t look quite right. After looking at them with the mirror, most of these were OK but the proseal oozing around them made them look distorted.
4 ? While you?re shopping for your mirror, get some AN470AD6 rivets to plug the tooling holes on the outer ribs. The holes are just the right size for these rivets. You can also make a little plate and attach it to the rib with smaller AN470AD4 or even AN426AD3 rivets, but if you?re already putting in a mail order, might as well spend an extra $3 and save yourself an hour of fabricating little plates, drilling holes, and riveting. Oh yeah, the $3 will buy you ? lbs of rivets, which is about 96 more rivets than you?ll need.
5 ? While you?re shopping for your mirror and AN470AD6 rivets, might as well also get some fuel lube (EZ Turn Lubricant)
6 ? If possible, get a helper for the riveting. When the tank is in the cradle, it was very hard to hold the gun to the rivets near the leading edge and the bucking bar on the inside. You *can* do it yourself, but it is so much easier to have one person shooting and another bucking.
7. MEK works very well at cleaning proseal. Unfortunately, it also works very well at melting everything else, including the lexan sticks, your gloves, your fingers, your EYES, your BRAIN, etc. So, wear a respirator and safety glasses *any time* the can of MEK is open.
8. I riveted all the ribs except for the inboard rib, and then put in the vent line. I think this worked out well.
I followed the George Orndorff philosophy on tank sealing ? if you can say ?This looks like there is absolutely no way this will leak, it probably won?t, but if you look at the tank and say ?it looks OK, probably won?t leak?..it probably will ?? We?ll see how this turns out when I put in the baffle plate and pressure test them?
Luis
