Kavlico fuell pressure sensor question
yankee-flyer
Just about ready to install the new sensor and notice that it's about 1/3 the size of the original-- about the same size as the oil pressure sensor. I assume I have the right one?
And does it need to be mounted at a 45 deg. angle like the original?
THANKS
Wayne 120241
PS-- I've done the Dynon update to version 5.5.0 and no longer get a low fuel flow alarm on take off. Now I get a high fuel pressure alarm! TMI!!!
Scott will correct me if wrong, but I believe fuel pressure sensors can be mounted in any position.
Joe is correct.
The angled mounting of the sensor is only to provide for aiming the hose fwd and outboard at a 45 deg angle for proper hose routing.
