kbehrent
My whale came in at 1155 lbs.
Can't say I was too surprised, but was hoping for lower since I'm still looking at putting a a Classic Aero interior.
I'm curious what others have weighed in.
Here are my specifics:
RV-9A Slider (carbon fiber skirt w/tip-up option)
IO-320-D1EMS with Hartzell C/S (Eagle EMS Electronic ING/FI)
360 lower cowl insetad of 320 for FI clearance issues (bigger snorkel)
PlanePower 60A Alt + SD-8 standby alt
ODY Batt (firewall)
7.6A backup batt for Eagle EMS system (behind baggage bulkhead)
Avionics - See my signature below for list
Gretz heated pitot
Strobes, LED Navs, Original duck work landing lights from Vans w/wig-wag
Interior - painted interior, leather seats, no carpeting or side panels (Yet!)
Crow camlock seat harness
No Paint, some exterior priming
Right Wheel: 423 lbs
Left Wheel: 422 lbs
Nose Wheel: 310 lbs
Total: 1155 lbs
I'm concerned about weight on the nose gear, but I'm probably in the same boat as others who have put in a (I)O-360 with C/S instead of a (I)O-320.
I might consider swapping my Hartzell prop for a Whirlwind C/S.
I can't exceed Aft CG without going way over gross. It's possible to fall outside Fwd CG if I'm full of fuel and weight < 133 lbs. (Not likely for me!)
Sent off my paperwork for my airworthiness certificate. My DAR is standing by for the inspection once the paperwork clears. It's getting close!
ODY Batt (firewall)
Gretz heated pitot
Left Wheel: 422 lbs
Nose Wheel: 310 lbs
Total: 1155 lbs
