wirejock
Jumper is probably not the right term.
I'm wiring the EMS harness. There are two positive wires that get shared. One is Pressure and the other is Fuel. Each needs to jumper to two others.
What's the best method?
I planned to use Faston insulated terminals. Same as the Dynon CHT/EGT harness. Main wire would have two jumpers feeding the two additional terminals.
