Ok I have searched the canopy skirt threads and still have a question about how one actually lays up the two pieces to make them one. I have the skirt clecoed in place all the way back and only have to join the pieces so that I can drill a hole and cleco it in the aft of the canopy. I guess my question is how have you all put them together, on the aircraft(I assume) did you build up the area under the canopy/frame and lay glass on it?
I have to keep the aft skirt taped with duct tape to hold the posistion I want it to have as there are no other holes to cleco to back there. If I remove the tape the skirts spring out of the posistion I want them in, so how do I hold them and glass them?
thanks
Jeremy
thanks
Jeremy
