RV7Factory
Chief Obfuscation Officer
I've recently made my first attempt at spraying the stuff, and while the first results are good, I feel they could be better. When spraying it appeared as if were going down really bumpy almost textured, so I wetted the parts a bit more to smooth it out but ended up with a small run. A painter I am not!
I've set my gun up per the instructions with 29psi at the inlet and reduced the JetFlex per the specs. The fluid control is completely open, and I've been experimenting with the fan control.
All this being said, does anyone have any tips or suggestions for spraying JetFlex WR?
Here's a pic of my Taupe interior paint.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
