Go for it
Bill Whidden said:
Any reason this set up won't work.
0-360 being converted to API's FI. The project I bought has a rebuilt pressure carb. What to do now with bendix pressure carb?
SELL IT
Buying SJ cowl and plenum. Don't really have a good reason except they claim 7-10 mph increase over the vans one I have now.
ITS TRUE
Changing out slick mags for 1 e-mag and 1 p-mag.
GOOD IDEA
Getting 4" prop ext. from Saber Manufacturing so my fixed pitched sensenich will fit the new longer cowl.
EXCELLENT IDEA, EXTENSION ON FIXED IS OK
Have a single egt guage. Should I change to 4-way egt being I now have fuel injection?
NICE IDEA, NOT A MUST, CONSIDER A 4-CHANNEL GAUGE JUST FOR FLIGHT TEST (FIND THE HOT JUG) AND RETAIN THE SINGLE CHANNEL
Anyone want to come vacation in Sunny Warm Florida for a couple of weeks to get out of the frigid north and help me put all of this stuff together??? Have spare room and car.
Bill Whidden
DO IT, It is like free speed and adding 15 HP that don't burn gas. All those who poopoo the idea don't get it or are jealous.
Bill the speed increase is built on sound engineering, physics and aerodynamics. NASA sponsored research thru Mississippi State proved this. LoPresti used this data to produce his aftermarket cowl mods for factory planes. Document performance and the fastest RV's have a SJ/Lopresti/NASA style cowl. Now even new factory planes have cowls that use these principles, but in my opinion Piper and Cessna are missing the boat and not executing the design quite to the extent it could be (but than they are building for the masses).
Yes a 4 channel EGT/CHT would be nice, but not an absolute must. The SJ cowl does not raise temps. In fact it takes the air it needs and does not waste it. The in let area may be 50% smaller but it is used more efficiently and thus you have less cooling drag. You want an explanation, check out the James Aircraft Yahoo group. Look at the first post on the list, which was only started about 6 months ago.
If you have a Sensenich, GET the 4" extension, no problem. The longer cowl is the way to go if you can.
As far as forward induction WHY WHY WHY? Yes it is cool and the promise of "RAM" air is calling, but there is a big problem. There is little room in any cowl to produce an effective "DEFFUSER", taking high velocity air and slowing it down to produce pressure and have a plenum volume big enough to feed the engine. The Van's style AIR BOX (FAB) for vertical induction is very very efficient. With vertical induction you have more room to make a diffuser, plenum and still have room for an air-filter. WHY DO YOU THINK VAN;S FWD INDUCTION AIR USES A "SNORKLE" THAT GOES UP TO THE ENGIEN INLET? The reason is just going forward and making a little constant cross section tube =with no filter is going to add "RAM" forget it. Also you will have lots of air spilling out and amount the "ram tube" creating DRAG.
People don't no know how to measure true RAM rise in the manifold and fool themselves into thinking they are getting something for nothing. Here is the break down.
>Factory Cessna/Piper induction, about 1" HG loss in manifold Pressure
>Van's old RAM air (unfiltered ) scoop, ab out 0"-.25" HG loss manifold pressure
>Van's FAB air box with filter about 0" HG (no loss/gain but low drag and filtered)
>Forward facing horizontal unfiltered induction, 0"-0.25" HG gain (most of the gain is the fact it's unfiltered).
Bottom line is 0.25" HG at 200 mph is a realistic expectation, which is worth may be 2 HP, 1 mph. However there will be more external drag. The vertical induction gives more room and places the scoop in clean air.
The latter solution is a Horizontal induction is unfiltered. To filter it is a bit of a pain with the limited space. Sam James has a fancy air-box that is filtered but it's RAM gain will be no better than Vans Vertical induction air box. Not having chin scoop is nice from looks but not real practical. Also sucking air in the cowl front just below the spinner, near the hub of the prop, is a terrible place aerodynamically. The prop is beating the air to death there. (The prop blades near the hub are blunt.)
I would get the SJ cowl with vertical induction if you have a choice. If you already have Horizontal induction than the SJ filtered air-box (tube) is the way to go.
George
